Hello - first-timer here. I have a question about a 10hp Briggs&Stratton motor on my generator.
It is difficult to start when at ambient temperature - even 70-80*F. Whether choke, no choke, crank - let it sit for 5 min, or give it a good stern talking to.
But if I remove the spark plug and add a small amount of gas to the cylinder - replace the spark plug, it will start, run fine and re-start for the remainder, as long it stays hot.
Any advice/suggestions would be welcomed. Thanks in advance for your in put.
