theplayer11
 - Jun 3, 2016
- Threads
 - 3
 - 15
Well, Ferris Site states:
FYI: the spindles have a large cavity in them for the grease to set into. You will find that it takes a larger amount of grease than everything else on the mower. Spindles should be greased until you confirm grease is pushing out of the weep hole located on the bottom section of the spindle.
So, why doesn't factory grease them fully? Took me 50 pumps to start seeing factory grease come out the weep holes on my new 600Z. I guess I should have checked before first mow, took me 3. There are also 2 zerk fittings under the seat with a bolt directly in front so no way standard fitting will work. Would a needle fitting work there..stick it right into the zerk?
