GravelyBrad
- Jun 19, 2016
- 10
I would like to give a short introduction. My name is Brad and i "tinker" in almost everything. Generally anything i want i buy it broken and try to fix it for myself. This gravely is an exception to that as i bought it working and it stopped on my hands.
What happened. was mowing medium-tall grass and mower stalled, and wouldnt restart (crank but wouldnt turn over). It was low on fuel so i filled it up and it didnt help. Drifted it into the garage and tried starting again. After cranking for like a half min it will start, but wouldnt throttle up.
So keeping a long story short, engine is 326437 0247-01 8005121 16hp briggs single cyl. Currently it will only start on low throttle and if i try to throttle up it stutters terribly untill throttled back down.
Here is a list of what i have done so far.
-Drained tank and made sure in tank screen is free and clean.
-Ran all new fuel lines and new fuel filter.
-installed a new fuel pump (runs off a vacuum)
-Cleaned and rebuilt carb (i am not a pro at this)
-Bought and installed new carb just in case i didnt rebuild properally
-new park plug (periodically recleaning new plug to make sure its not getting fouled from carbon)
-made sure governor is adjusted properly.
Tested compression (3 results ~120)
Here is what i (think) i know
Spark seems to be strong
compression seems to be good at 120
not a fuel delivery issue as when i try throttling up and its stuttering a small spray of starter fluid does not help.
If i try to throttle up very very slowly it will sometimes throttle all the way up but as soon as there is any kind of load (moving/ turn mower on) it goes right back to stuttering and whatnot.
Please any help would be appreciated as this is the extent of my small engine knowledge which is get it air/fuel/and spark and it will run. (clearly im wrong) Since this engine is so very old i am finding very little information on it.
