Mike Green
Toro 266H Year: 1994
Model: 72083 s/n:4901032
Kohler Twin V CV16S
Spec: 61514 S/N: 2408009097
Hi - My first post.
I have been cutting grass with my Toro since 1994 - about 900 hours. Other than belts, never had a problem.
Last week, in the middle of a cut, the mower died. Troubleshooting showed the 30 amp fuse was gone, and the PTO switch was not making any of the proper contacts - "1" and "3" were always OPEN (safety), "1" and "2" were always OPEN ((PTO Engage), regardless of whether the PTO switch was pushed IN or pulled OUT.
I bought a new PTO switch and replaced the 30 amp fuse. The Toro started immediately, and I began to cut grass. After 20 minutes of easy cutting, it died again. The 30 amp fuse blew. The new PTO switch checked out perfectly. I changed the fuse again, and it wouldn't start. I could not detect that any dash lights were on. I jumped the starter, and it would not start.
(The battery is brand new, and checks out at just under 13 volts. Battery connections are good at the battery and engine ground end.)
Just for the heck of it, I tested all 4 relays - they all checked out.
I'm wondering about a short somewhere along the wires powering the PTO, or maybe the PTO is drawing too much current when it gets hot after say 20 minutes of use.
1. Does it makes sense that the PTO clutch will work for a while, and then draw excessive current to blow the 30 amp fuse?. It currently has an impedance of about 2.5 ohms. I priced a new PTO clutch, and I was quoted $800 Canadian. If true, this is insane.
2. What would cause the PTO switch to go? Just age and and too much current draw?
3. Could this be an ignition switch problem?
3. Any other ideas that would cause this problem?
Note that the deck is in good condition, I can move the belt by hand easily, and all the bearing were AOK as of a month ago. Nothing is binding. The grass barely needed cutting, and the ground is fairly level.
I will try jumping the starter and starting it tomorrow. (I was able to do this successfully the first time the problem occurred.) I will also look for a short tomorrow.
Thanks
M...
Kohler Twin V CV16S
Hi - My first post.
Thanks
M...
