Dutchtasitc
never mind it is getting late and i'm not thinking right.
No problem my IQ is falling by the minute. Thanks for your thoughts anyway. Any input is helpful, so appreciate it
Okay, I think I've got it. If I am correct, this is your issue:
1. You have a PCV tube coming from the engine, but can't figure out how to hook it up to the carb.
2. The carb has an inlet for a PCV, but there's no way to hook it up.
On some Tecumseh engines, the PCV tube coming from the engine DOES NOT hook up to anything. I know. I have a Tecumseh like this.
The carb you have is not the right one for your engine (it has a PCV inlet) but that shouldn't keep the engine from running.
Spray some starting fluid into the air intake and try to start the engine.
The inlet on the top of your carb doesn't hook up to anything on this engine. Just close it off. The inlet on the side of the carb is for your fuel line (from gas tank to carb.)
