Ironhead Dave
- Jun 2, 2013
- Threads
- 4
- 14
I have a cub cadet rtz22 with a 22hp Intek. About a month ago it started backfiring through the carb at high rpm. Since then I have checked and gapped the plugs. Checked for good spark. Cleaned the flywheel and coils. I pulled the plug wires one at a time and it is on the left cylinder when you are sitting on the mower. With that and all the easier stuff done, I did a compression test. About 105-110 both side and less than 5 psi difference between the two. I switched plugs from side to side. No change. I switched coils. No change. So that leads me to believe that it is not ignition related. The timing could cause this but since it is basically fixed between the cylinders and only one is doing it that the timing should be fine. Feel free to correct me. So the next obvious choice, at least for me, was an intake valve sticking. I pulled the valve cover and with the plugs out I turned the engine by hand and everything looked good. Nothing tight or loose (just judging from past experience. Nothing official). Pushing in the rocker everything moved freely. Since it is high rpm only, I thought maybe a weak valve spring. I bought a new spring and pressurized the cylinder with about 80 psi and removed the spring. I did not hear and air leakage while doing this. I released the pressure and made sure the valve moved freely. I installed the new spring and I adjusted all of the valves. Turned the engine over a few times and checked them again. Put it together and it started and ran great for about two hours and then started backfiring again. This time it started blowing some blue smoke. I checked the valve adjustment and it is fine. This engine does burn some oil but we check and add as needed every time we fuel up. It has about 500 hours in it.
I am fresh out of ideas.
