jakesmurray
This engine will start right up cold, run for about two minutes, then surge a couple times and die. I completely cleaned the carb, replaced all the fuel lines, and put new gas in it. I'm thinking the needle valve may be sticking, causing the fuel pump not to pump. Could this be the case? Once it dies, it will not restart... Any help is appreciated. Thanks.
