desertrider
- May 17, 2016
- 3
Owned, ridden, and worked on motorcycles since I was a kid. Couldn't afford to take my bikes to the shop for maintenance, so if I wanted to ride I learned to wrench on them myself. Same train of thought carried over to my trucks, and also to my lawn equipment.
I am completely stumped with my FS 55 and HS 45 though.
I drained the fuel and pulled the carbs. All diaphragms and gaskets were delicately and carefully removed and inspected, no tears or pinholes.
Pulled the main jet, float jet, and high and low speed needle jets, checked their condition followed by full sprays with Berryman Chemtool and then compressed air in all orifices. Primer bulb is good and works, even tried with gas cap loose just in case the cap is plugged.
New spark plug properly gapped and strong spark is present. Good compression on the FS 55.
Pull, pull, pull, pull. Cuss, swear, stomp. Repeat.
Tool won't start.
What did I do?
Tool won't start.
What did I do?
