190cc engine won't start
tricky
I have a Toro lawnmower with a B/S 190cc ready start engine that won't start. If you spray starting fluid it will fire up but die after fluid is gone. Acts like it is not getting fuel. Loosened nut on bottom of bowl and fuel is running out. Whats next
Remove the nut and clean the jet that is inside the nut.
tricky
Thank you ILENGINE, I did as you said, and it is running like new. The jet looked like it was clean, but when I tried to shoot some carb cleaner thru it, it wasn't. Thanks again
Thank you I will try that when it stops raining and let you know
