I don't know. I've been in this place for about 7 years now. I bought a riding mower (used) the first year. It ran ok. On the next year it needed belts & spindles. Ok, not life threatening so I fixed it. The third year the starter wouldn't turn the engine over, even with a jump from one of the cars, so a new starter was replaced & it worked fine.....for that year. Next year, even after new fuel & an oil change it exhibited the same starter problems. A brand new mower was available at Home Depot so I went for it. Now, of course after the warranty has expired, it is doing the same starter problem as the first one. Being they are both Briggs & Stratton engines & the same cylinder setup I have my reservations about their products. I have just over an acre & a quarter to mow, & only have to do it maybe 4 times a year if that due to the drought & nothing really grows & the sprinklers have been turned off for about 4 years now. But the weeds are getting high now & I don't need a ticket from the fire department. New gas, Sta-bil, carb cleaner doesn't do anything. I'm open to suggestions.
If you checked the service schedule you will see that at 50 hours thence every 200 hours there after you should check the valve lash.
As the cam, rockers, pushrods wear the gap between the valve & the rockers open up to the point where the inlet valve no longer opens just before TDC at cranking speeds to allow some decompression.
Without the decompression the small starter motor does not really have the balls to turn the engine over.
So you get a new battery and for a few mows it works because a very new battery wil put out 13 V and that little bit extra is just enough to overcome compression.
Then it stops again so you go out & buy a new starter and being new it has a touch more grunt, and again manages to overcome the excessive compression for a while.
Then it stops again so you hook the jumpers onto your truck with the engine running putting out 14 V again allows you to start this useless piece of junk. All the wile the gap is getting bigger and starting is getting harder.
Then you get the tom tits and sell it to Renylson, for $ 50 vowing never to use one of these junk B&S engines again.
He adjusts the valve lash and replaces the rocker gasket then sells it next week for $ 500 hoping to find you brother with his shi* box Briggs and see if he will take $ 50 for it as well.
Now if you are really good you will try 24Volting the starter to get this cr*p pile to go and the 24V will dothe job as the starter wizzes over the excessive compression, taking the head gasket with it.
Your deciples come into my shop at least 10 times a year.
Most having forked out around $ 500 in parts because they did not bother to read the Owners handbook and were too pig arrogant to pay a professional who knows what they are doing to service their mower.
After all it is a lawn mower, not the space shuttle, any fool can service it themselves, and most do.
But don't believe me I am one of the conspitors trying to dip my tallons into your pockets .
In the top left corner in a search box.
Type valve lash in there and see just how many owners managed to fix their unfixable mower in 15 minutes by adjsting the valve lash.
