Walker steering issue
Powerphoto
I have a 1996 MT AND it pulls slightly to the right, also when I pull back on the right lever it struggles to turn right please advice on what the issue could be.
Thanks in advance
Thanks in advance
Sounds like your lever needs to be adjusted back just a bit. Not sure about walkers, but on my Cub there is just a bolt that allows you to slide the lever forward or back, and this is separately of the other lever.
