Carl in CT
- Mar 22, 2011
- 56
I suppose it's not going to make a huge difference on an acre lawn with a ZTR, your mowing time will be good either way. If you gain 6" per pass then you gain a foot going up and back once so after 4 passes you've gained 4 feet which gains you one whole pass. On an acre that probably doesn't equate to that many passes saved and how much time and fuel will each pass save, probably not that much.
I see Cajun Cut's point about the blade tip speed with the longer blades on the 2 blade decks but that extra blade length could also amplify a blade that is a little out of balance which would wear on the spindles more. I honestly don't know if the extra blade speed or potential amplification of imballanced blades would really make much difference between a 42" and 48" deck, probably not IMHO.
I still would prefer the 48" deck but $600 isn't chump change. I don't know if a 48" deck would increase resale value down the road, or if that even matters to you. I think you will be happy either way so maybe the extra deck size isn't worth $600. Is that the only difference or is the enigine different/bigger on the 48" deck?
