10515 fuel leak
mulligan
My 10515 is leaking fuel after the shutoff is closed. Is there any way to repair this or should I just order a new shutoff valve kit part #681818. I probably just need the rubber washer but I dont see that part availble alone.
Top quality mower takes top quality parts. Maybe you can make a new washer but make sure its gas resistant.
I believe that part is discontinued and hard to find you make have to make your own using a leather punch and dye kit and gas resistant rubber both of which are available on ebay turning the rubber gasket around is not the solution
