hannachris
- Mar 30, 2016
- 6
The oil is mixed with gasoline
I removed the filler neck completely and about half a gallon of oil/gas mixture came out.
The engine didn't rotate fully counter clockwise, just about 1 turn then stopped. Starter motor appears to be fine.
Thanks
Thanks
If oil comes out of the filler neck then there was too much in the crank case.
Oil level should be just below the hole in the crankcase once the rubber grommet that seals off the dip stick tube is removed.
Now you say the engine rotated counter clockwise but not clockwise ?
Or the starter motor rotates one way & not the other.
If the starter is not jambed into the flywheel the motor should turn in either direction with roughly the same effort.
