Quick Question
jmurray01
, , 1,000 Post Club
I've just had a thought... Could my "no starting and kickback" symptoms I had with my 3.5HP B&S push lawn mower a couple of weeks ago have been down to a flooded engine rather than sheared flywheel key ?
Just a thought...
Three things can cause kick back. Damaged flywheel key, loose blade or fluid in the combustion chamber. To clear the flooded engine, remove spark plug and pull start cord rapidly several times.
In my case it was a flooded engine. I wasn't in a rush (as it happened after mowing the lawns), so resolved it the long way - Left it in the shed for a week to dry out.
FYI a few years ago a had a rider that had flooded the engine after transporting it about thirty miles. pulled the plug, gas ran out, while sitting on the seat and holding the disconnected spark plug in my hand, the the spark plug wire was about four inches from the engine cranked the engine. The first crank blew out raw gas, the second crank lit it and lucky I had a fire extenquisher in the truck otherwise I may have lost the lawn mower and my trailer. since then I have always blew the cylinder out with compressed air.
Woah - hadn't thought of that. This little bit of safety advice should go in a FAQ or something on flooded engines. Thanks for the tip.
Note that I said to remove the spark plug before clearing the engine, the fire that was mentioned is the reason.
Sounds like ilengine removed the spark plug - the ignition came from the dangling spark plug wire.
