Murray Model 46581x92 Deck leveling and adjustment
geads
Can anyone help me with how to properly level and adjust the 46" deck on my Murray 46581x92?
I use to have a Murray rider. I would move the black plastic piece and move the deck height selector all the way down. Loosen knobs on both sides then push lift links down on each side. Tighten knobs up and move deck height selector back up to normal. I would fine tune height if needed after a few cuts. Need to have a level place to do this at.
youtube.com/watch?v=O0YERh8Q7Hs
This video shows nothing, if we should use that as a tutorial... I can tell you how to do it right now without even going to the video
Level the deck...
That is about as good as information you will get from the video....
