Maxrevs
- Feb 15, 2015
- Threads
- 11
- 46
Hi all,
How do you guys tie down lawntractors on a trailer so the tie-down straps don't bounce loose?
No matter how tight I get the ratchet straps, one or two always seem to come loose.
I know how they're coming loose but I can't find a way to prevent it. The trailer is a 7x4 with sides & loading ramp, it has balloon tyres, no suspension - bumps in the road make the trailer bounce, the mower's tyres compress, creating a momentary slack in the strap tension which can cause the strap hooks to unhook from the trailer hooks/cleats.
I currently use three ratchet straps from side to side: over & around the front and rear axles, and one over the driver's footwell.
