- Nov 29, 2014
- 24,995
Nothing to be stumped about.
Without the blades engaged or fan blowing there is effectively no load on the mower so it chufFs along happily.
When you put a load on the engine, the engine slows down so the govenor should allow the throttle to open further.
Yours is obviously not doing this and you were told to check this a while back but obviously have not bothered to do so or if you did you did not bother to tell us .
You were also advised to check the pipes for even amounts of heat signifing the engine was running on both cylinders, again with no response from you.
If this is the level of communications you have with the "experts" no wonder they are stumped.
