Mower Repair Equipments
William Thomson
Hie..
Through this article I will suggest you the basic steps of repairing Mower-
You should disconnect the spark plug lawnmower before you start with the repair so that their are no chances of the engine starting. It is good to wear working gloves, because engines have sharp blades and dirt which can give you an infection. For Eye protection wear glasses so that gasoline and dirt do not end up in your eye.
I hope you are comfortable with this tip. :smile:
Hie..
I agree with some of this some I don't. disconnect spark plug- depends what you are working on, some repairs you will need the engine running. wear work gloves- depends on what your are working on- you ever OH a engine with gloves on, try it once. Eye protection Yes all the way.
Best tip I was given, which I made sure my students had to remember on the final exam was: Before you start repairing any piece of equipment, know what can happen if you do something wrong". This means the first tool you should USE is your brain.
