Wanted: Wiring diagram for briggs
You could use the charging system from the 16HP engine if it is a Briggs engine by replacing the charging stator and the voltage regulator. I have used these two with success. 10 to 16 amp charging system. Notice the yellow plug on stator matches the yellow plug on the voltage regulator and the voltage regulator must have a good ground or it will be damaged.
I don't think I have a voltage regulator on this one that I can find.
the pic I posted are the yellow connectors which are 10 to 16 amp charge rate all depends on the size of the magnets under the flywheel. At 10 amps with the smaller magnets will work to keep battery charged for electric pto.
Stator part # 592830
voltage regulator part# 797375
How do I know that it will fit my motor?
