Etesia Ride On Mower Electrical Loom Help
Hi
It's the baiha mbhe model not the baiha 2 mate.
Yeah I'm trying to get it back to standers.
Now that you have posted the wiring legend, I go back to the original reply.
They are all earth wires.
21 - 22-23 & 29a all bolt onto the engine at one end.
29a (one end) - 21 and 25 all go to the starter solenoid earth terminal.
heck the ignition switch for continuity between the G ( ground ) terminal and the M ( magneto ) terminal.
These two close together to stop the engine by earthing out the other side of the ignition coils.
Hi
Well go the tester out and checked between the G and M terminal beeped on first key point then nothing on start and run so that's all ok.
Wired it as you suggested still nothing. Tested all the switches separately and all work fine so still a bit confused as to what's going on ??.
I Found an old picture of the mower when I first got it of the wires on the solenoid and there different to how they are now.
Here's it today after moving some wires
Library Slideshow by kevjns | Photobucket
attached pic is of how I got it
IF the grey wire on the solenoid goes + 12V when the key is in the start position then the other terminal needs to be negative or the starter solenoid can not work.
As to stopping
Where does the green wire on the control plate go to ?
Normally that would be a cut out wire for engines that have a pull start and the green wire will go to the cut out wire on the ignition coil.
Check that it closes to earth when the throttle closed down.
Normally you would not run a throttle stop and key stop on the same engine.
