Lawnmower
Lawn Mowen
Does anyone have any ideas about what type of lawnmower to buy
Alpacas are better.
They are trainable on par with a 1/2 smart dog.
They will chase off foxes & snakes
Always pee & poo in the same spot & ncan be trained to do it where you want it.
Wool is on par with cashmere
Meat is a little more game than lamb but not as much as mutton
sirrobbins
so many factors into one of the most generic questions. More details on what you're cutting, where, how much, residential, commercial?
AllenPKang
Rotary lawnmowers work quite simply by rapidly spinning a blade to cut grass. They're heavier, but provide more power.
Snapperfreak
If I was going to buy a new lawnmower (I'm assuming we are talking about walk behinds) the ONLY one of get is a Honda HRX217HYA. Middle of the road price, around $800 or so. Not a cheapie but not a full commercial for twice that. YouTube it and you'll see why it's such a good choice. I have an older (early/mid 80s) HR219 that's basically the same thing only in a 19" deck. It's amazing to use. The rotostop works great, always easy starts, drive system is awesome. Mine only has two drive speeds but the newer ones have an infinite setting of speeds between low and high. Check it out if you want a good mower that will probably outlast you. My .02.
teetertotter
How about supporting an American business lawnmower maker???
teetertotter
Gees, do you live in the desert, like AZ/NV, and don't have to own a mower??? Where did you get such mower knowledge? Can you share with us?
