Converting from Kohler to Techumseh. I need the troy drive pulley with a 1 in bore. It comes with 3/4 bore. Any ideas where I can get one. Online searches have come up empty
Thanks
Is the hub large enough to allow boring it out to 1 inch... much simpler and easier ... :smile:KennyV
Can you give the pulley o.d.-width/belt width & set screw or key groove. Maybe I can look around here.
Cutting the key way would be the issue.
rcholtorf, I found this one very close to what your looking for....(part# 3X316EMW) 3.55" 1-1/8 $60.70at this site:
Browning Double Groove A/B Pulley for Electric Motor
Hope it helps...
