Can anyone identify this part for a Simplicity Regent Tractor?
cpalma
  • / Can anyone identify this part for a Simplicity Regent Tractor?
I recently removed the 44" mower deck, on my 2012 Simplicity Regent tractor, to sharpen the blades. I then replaced the deck and cut the lawn. The next week I noticed the attached spring, lying on the deck, under the belts:
I scoured manuals and parts lists, but cannot find this part anywhere in the diagrams of my mower deck. It's clearly not the big spring for the belt tension, and it's not the spring for the hitch (both are still there).
Can anyone solve this mystery?
Thanks.
Chris
mechanic mark
Post your 7 digit Simplicity model number as well as all numbers from engine data plate, thanks.
Catherine
LawnWorld Support
Staff member
Welcome to the forum!
:welcome:
I'm going to move your thread over to the Simplicity section in case you need a few more minds to solve the mystery.
cpalma
mechanic mark
Results Information including wiring diagrams. Without removing deck, check front hitch & see if spring is missing, located in illustrated parts list pages 70 & 71 item 11. Springs hooks from raised tab in hitch to center of rod item 2.
Jimmyjo
Clutch return spring. From clutch to a hole in frame. Lost mine also and found it on the mower deck.
