Honda Engine Identification
XD2200
I have a SCAG Tiger Cub with the Honda 24HP V-Twin Model DXV670) engine. Where would the serial number be located on this engine?
THANKS
THANKS
Do you mean the GXV670? If so, look on page 13 in the manuals below and it shows you where it's located. I am not sure which manual is for your exact mower because you need to know the serial number to figure that out, but these are all for GXV670's. Make sure what the manual is describing is the engine you have, because I just looked up the GXC670 on the website, I'm not positive it's the 24HP V-Twin.
1) GJAH-1000001 through 9999999: http://cdn.powerequipment.honda.com/engines/pdf/manuals/37Z6E603.pdf
2) GJAHK-1000001 through 1002722: http://cdn.powerequipment.honda.com/engines/pdf/manuals/37Z6E603.pdf
3) GJAHK-1002723 through 9999999: http://cdn.powerequipment.honda.com/engines/pdf/manuals/00X37Z6E6110.pdf
Sorry - yes it is GXV670. I found the S/N - it is located on left side of engine between the starter and the front of the engine.
THANKS
