NorthBama
Trying to help a friend with a problem on an old Gator utility vehicle. The engine is a Kawasaki KF82D-x that does not have a spark at plug. The engine has an exciter coil behind flywheel and another coil mounted under flywheel metal shroud. Anyone that could give me any help troubleshooting ignition system would be great. If anyone has a repair manual in PDF format it would be great also. Thanks in advance for your help.
