I liked the overall machine of the Hustler, but the cut quality just wasn't there.  I had an 03' TT before it and it would go through anything.  Had close to 2k hrs and it blew headgasket so went ahead and sold it.
			Don't ***** foot around. Find your nearest dealer that you feel you can work with and get the best deal you can on a new Tiger Cat with the Kawasaki engine. Do I think the Kawasaki is better?...I hope so because that is what's on mine but before that most commercial mowers I used before had Kohler or Briggs & Stratton and were excellent.
Same pricing here
I don't think the tires are wider but I do think the width of the machine is wider. You can look at the two side by side and see that the Turf Tiger is lower slung so I would imagine it has a lower center of gravity which would make it hold hills better.Does the Turf Tiger have wider rear tires than the 61" Wildcat and Tiger Cat? I noticed while using my buddy's Wildcat it wanted to spin and not turn real easy on my hillside thet was no problem for my old Turf Tiger.
Bear in mind that the engines on Tiger Cats are vertical shaft and Turf Tigers have horizontal shaft engines. It is generally accepted that horizontal shaft engines live a longer life than vertical shaft engines because of design and other various reasons. Keep in mind that most or all small engine manufacturers have improved the effectiveness of the cooling systems on their engines as EPA emissions requirements have stiffened and the negative affects of ethanol in the gasoline have become more evident.
I wasn't comparing those two engines against each other in regards to Hp. Actually just trying to determine Koehler vs Kawasaki on Tiger Cub/Cat and vanguard vs Kawasaki 29dfi on Turf Tiger.
