B [email protected] Forum Newbie Jul 15, 2015 #1 John Deere 100 series 102 5 speed brake pedal is frozen How can I get the brake pdeal to release?
lugnut1 Active Member Jul 15, 2015 #2 only advice I could give you is to go through braking system and check for any binding and or adjusting of linkage, etc. (sometimes you get lucky with a shot of wd-40 and or grease in the right spot) found this: (not sure if it pertains to your mower or not) HOW-TO: John Deere L100 Lawn 42" Tractor/Mower Brake Adjustment (Andrew's Blog 04/19/2009) Last edited: Jul 15, 2015
B [email protected] Forum Newbie Jul 15, 2015 #3 lugnut1 said: only advice I could give you is to go through braking system and check for any binding and or adjusting of linkage, etc. found this: (not sure if it pertains to your mower or not) HOW-TO: John Deere L100 Lawn 42" Tractor/Mower Brake Adjustment (Andrew's Blog 04/19/2009) Click to expand... Thanks I did copy the How to on the John Deere not exactly the same but close ehough for me to try Thanks again
