I remember how the temp test was done on the transistors. They would douse them with CO2 (I think) , a fire extinquisher? Anyway, it was a spray that took the parts down to cold very rapidly.
TRIVIA (what else) . Plato probe that is quite impressive has components known as "trace." Each transistor is tagged and documented from the minute it is formed in the foundry, diced into little squares, die bonded with little wires, burned in (like your tractor parts should be), temp cycled -cold hot cold etc. Finally issued a pedigree as "fit to use" and sold at a zillion times the chinese battery charger price. I know y'all needed this....:confused2:
