Removing mower blades
SeniorCitizen
I don't have a clue and I'm not worried. I know it's not enough to damage the threads and It's enough to hold the blade.
There was a tire shop with employees with your same attitude. I did say was because it eventually went out of business because of twisted off lug bolts.
turboawd
you aint gonna snap a 5/8 grade 8 bolt with an impact. plus most wheel shops just use an impact to install lugnuts. rarely do you see a guy use a torque wrench. and many impacts put less torque going forward versus reverse.
gabowman
Being 58 yrs old and was made to cut the grass when I was a boy I'd say I have some experience with mowers. That being said....I've NEVER put a torque wrench on a spindle nut and I have never had one to come off because I left it too loose. As stated before, I use an impact drill to remove and tighten the blades and ALWAYS use anti-seize.
SeniorCitizen
They'll only do it on mine once. When a breaker bar with a 4' cheater is needed to take a wheel off I don't go back to idiots.
turboawd
better than being loose and your wheel falling off :confused2:
KrashnKraka
... an' there is always that mighty Interwebs as a backstop for owned silliness, hey :frown:
KrashnKraka
... I can hear you have never had stressed wheel studs let go, at speed.
I wish you never have to be there to control a >3tonne payload whilst your
front nearside skips out in front of the vehicle.... showing it's brand new
shiny tread.
Life gets very interesting very quickly :tongue::tongue:
As others have tried to air, there is fixed (to) and there is tite. Pros know the difference
and why :/
KK
