Vervepipes
- Mar 25, 2014
- Threads
- 13
- 357
I took a few days off of repairing stuff but got back in the game today. This Yard Machines has a new style of deck that I don't have a bag for. The deck has a flat round spot where I assume the higher end models have a hose quick connect fitting. The wheel adjusters are neat, one lever for the front, one for the rear. When I got it, the engine wouldn't turn over and the deck was coated in oil. Upon closer inspection, the oil was topped off right to the top! I drained enough oil to bring it into the normal reading since it looked like new oil, pulled out the spark plug for a few pulls and re-installed it. It would run for a second then die. I checked the gas tank, milky brown and stinky. Drained that and mopped the bottom of the tank with a rag to get all the water out, fresh gas put in and it starts first pull. Here she is all prettied up and ready to sell.
I generally try to avoid electric mowers, but this one seemed like an easy fix. It's a Job Mate, the motor would run as long as the cord was plugged in. I took the lever assembly apart and found the switch to be stuck. I freed the switch and it runs quite well now, and very light.
Tonight I also picked up a nice Homelite aluminum mower with a Briggs Quantum. It looks to be built by Jacobsen and is a very sturdy mower. It is very similar to hanyoukimura's Jacobsen but a few years newer as it has an engine brake and a Quantum engine. That one will be a keeper as well, as much as I "hate" having more keepers when I'm trying to make a few bucks. I have a 6.75HP quantum on the Deere that could go on this deck as an upgrade as well if I really wanted to.
I've also sold everything I had for sale up to this point, so the two mowers above are all I have ready to sell now. I also got off my butt and bought a $1 toothbrush to detail the wheels with.
