- Nov 29, 2014
- 24,995
It is the orange ring you can see in the bottom of the primer.
It is a very cheap but remarkedly effecitve one way valve
Now because it is easy to get things wrong.
The primer should connect to the bigger spigot on the carb then go to the return line to the fuel tank.
The small tube on the carb should be connected to the furl line with the filter on it.
