Craftsman Riding Mower Model 31A707 Trans problem.
slick49
Craftsman Riding Mower Model 917.273351 Trans problem.
I changed the model number from the original post. I had the engine model number originally. I have a Craftsman Riding Mower...Model #917.273351. Built between 1993-2002. I think mine is an early 2000.
Here's my problem. If I'm in neutral and put it in any gear forward or reverse, it will not come out of gear.
Most of the time it will come out if I let the brake/disengage pedal out a little bit and have if move. I push down the pedal a little (not hard enough to set the brake) and pull the lever it will come back in neutral.
Whatever gear I put it in forward or reverse it will not come out unless I do as I stated above.
Sometimes I have jacked the rear of the tractor up with both wheels off the ground and spin the tires, it will come out of gear.
Is there some type of adjustment or do I have a problem transaxle?
Thanking you in advance~~~~~~~~~~~Ron
Assuming its a peerless transmission then it sounds like the keys are are worn
Instead of having a sharp edge they have a round edge which causes the key to jump out of the gear.
How do I fix the problem if it is the keys?:frown:
It all depends on what model of transmission fitted.
You will have to remove from tractor.
Strip down the transmission and hopefully the keys are still available.
Try your local machinery dealer.
Keys have been discontinued. Now I'm between the rock and the hard place. Any suggestions?:confused2:
Re: Craftsman Riding Mower Model 917.273351 Trans problem.
I can't locate any parts for this model of transaxle. Decided to leave it in 4th gear and never shift it. It is parked so I can drive right through my garage and never have to back up. I always mow in 4th gear.
I can buy a replacement Dana 4360-140 for $299.00 with "Free" Shipping. But it will be the same piece of junk I have now.
I'll mow until the motor blows up than buy a replacement commercial grade John Deere Garden Tractor (not lawn mower) from a reputable John Deere Dealer. Not a box store throw away that John Deer makes to compete with the rest of those throw away lawn mowers. Shame on you John Deere!!!!
Anyone have any suggestions on a replacement garden tractor besides John Deere?
If someone has any other suggestions about fixing this transaxle.....Bring them on!!!:confused2:
