tecumseh tvxl220 crankshaft balancing
oiu789
On a tecumseh tvxl220-157202 vertical shaft 10hp engine is the crankshaft balanced with the flywheel or can you use a flywheel from a different engine?
I have a 2 tvxl 220 flywheels one with 3 magnets in it and 1 with 5 magnets I want to use the the one with 5 magnets in it because it is the one that came with
the alternator stator I am using. The crankshaft it is going on had the flywheel with 3 magnets. Will this work or will the engine not be balance right. I need to know if the crank and flywheel is balance as a assembly or independently.
