Choke linkage question.
LaWn GuY
I took my carburetor completely off and disconnected both linkages and a breather hose to give It a good clean also removed the float bowl to clean. Got done put everything back together and the choke linkage that attaches to the side of the engine block came off I put It back on but not sure I put It on right. When I engage the choke on the lever the choke engages all the way, but when I turn the choke off the choke flap Inside the carb only open's half way Im not sure If that's normal or not. If I manually move the choke I can open the flap all the way.
