need help with ignition coil module on 1980 R7070
razman
i have a 1980 2 stroke 21" push Lawn Boy which i love...problem is that i can't seem to keep it alive!! i have replace the ignition coil 3 times in last year, once with the high dollar original style from Lawn Boy dealer, and 2 times with Ebay Taiwan replica....the one from the dealer lasted half of a season, the others lasted about TEN MINUTES!! can someone tell me if this is indicative of the new coils or am i possibly doing something wrong with installation?? this is getting EXPENSIVE! thanks for any help you can offer. Rick
lewb
Do you set it with a business card? Placing the card between the magnet and the pick up? Heat is what takes them out usually. Hard time believing that a new part only last a few hours. Something else must be going on? Might try a different fly wheel. What is your oil ratio at? 32 to 1, can cause more heat with a lighter ratio.
jp1961
are your cylinder fins reasonably clean? Heat can kill them too.
Jeff
razman
installed each new coil with the business card method...aprox .010 air gap.....i am using newer synthetic 2-stroke oil additive (good for all 2 stroke engines) with my gas. cylinder fins are clean. this is the THIRD one in less than a year, 2 of them only ran 10min or less then died, no spark after that...what's going on here??? Rick
lewb
I would try a different flywheel as that is the only other component related to the cdi.
motoman
I do not know your machine... Do the replacements look identical to the original? The 2 strokers run high rpm and require ignition advance. This is achieved by the shaping of the "shoe" portion of the module. I saw a patent on line for this dated around 1977. I wonder how models in the 1980's differed. Were there different models of coils? You say they all work and then fail, but do they work like the original before failing? Heat does kill and although Taiwan is usually a cut above there could have been low grade parts in those . Did the plugs look normal after failure? Could you be suspecting coils when other things could be causing the problem? There are some very knowledgeable 2 stroke guys here.
razman
replacement coils are identical to original coil.....spark plug looks fine, and works fine when coil is replaced. i ordered a replacement (used original) from ebay, and will replace it before tying another coil. is changing the flywheel a big job? any tips? thanks, Rick
Phototone
Changing the flywheel to another identical one is easy peasy. Just one center bolt on the flywheel, then knock around the edge with light taps from a hammer while pulling up on flywheel. BUT....are you sure you lost spark? A good coil will produce a spark across a plug just by hand-turning the flywheel rather rapidly clockwise (looking from top). Clamp the engine brake off at the handlebar using vise-grips, or other way to keep the bail against the handlebar. Disconnect the kill wire from the coil. Take the sparkplug out and with it connected to the spark-plug wire coming from coil, hold it tight against cylinder fins, spin flywheel and you should see spark. If you get spark, then reconnect kill wire and repeat. You should STILL get spark. The kill only kills when the brake engages. You can see this function, unless your machine is old enough to be before kill switch/brake stuff. In any case, you should test for spark visually, by viewing the sparkplug. Older pre-compliance models have a separate on-off switch to ground the kill wire. Same principle. First test with kill wire disconnected, then connected, then test both on and off positions of switch to be sure it is working. Off should produce no spark.
The flywheel (its finned to act as fan blades) and shroud form a blower system to constantly push air across the coil and cylinder fins. If there is a piece missing, or any air inlet partially blocked with debris then the cooling will be poor and the coil will be more prone to failure. Often times a Lawnboy ceasing to run after it warms up is due to very bad crankshaft seals, rather than spark.
razman
yes, i have checked for spark...no spark. even ran ground directly to coil bypassing the on/off switch....no spark. thanks everyone, i'm putting on a used original flywheel and a new coil...we shall see huh? Rick
lewb
The key on the crank can be corroded and may be a little hard to get off, just use a penetrating oil and lightly tap with a hammer, be careful to not damage the key if you plan on reusing it. The key should stay in groove in crank.
