Mower won't run properly
Supplementry:
You do have the belts off engine pulley when doing your tests, hey?
KK
I don't have the belts off but I think I figured out a problem. In my engine that hole I was talking about is where the main jet for the carburetor is supposed to go and it's not there so I ordered one and hopefully that will fix it
That'll do it. Well done :-)
Leave the belts off to set engine speeds etc, the governer should pick up the load when the engine is put to work.
Post the outcome if you wish to.
Cheers
KK
