LaWn GuY
- May 19, 2014
- 82
What the title says It's running rough and backfires sometime, and will act like It's going to stall but revs It's self back up. Also when I tried to start It this morning It started then ran rough for a few second's and stalled would not start unless I put the choke on, and would stall If I didn't play with the throttle. When It was about to stall I had to put the choke on or It would have stalled. I let zit run In the garage for over a half-hour and It didn't stall once but was still running rough and occasional backfire. Also It will run with the choke on for about 15 seconds then start to conk out. In the mean time I have to replace the starter pinion gear since that's chewed up.
