Shughes717
Did you look at the pictures in the link above ? You want to use the mower for a Business and that's the SD. Yes I suggest the Raptor all the time... to a homeowner with a half acre or less of property for there personal use and for what it is designed for (a once a week mowing) but not for a business. PVHlll is right the mower and the decks aren't made for commercial work.
That op on that thread is having some trouble, but there are other owners out there who aren't having any trouble with their mowers. There is another thread on this site about several other brand mowers having this same problem. There are many reasons why a mower streaks a lawn. Hopefully that op will figure out the problem with his mower, but you can't tell me that a mower with a 54" deck is only designed to cut a half acre. secondly, if the op is push mowing lawns now then he is mowing lawns smaller than a half acre, and I'm sure the push mowers he is using have shallow decks that are not nearly as heavy as a commercial ztr mower deck. Mowers are not built to only run 30 minutes a week. I don't see your logic that a raptor will mow the first half acre fine, but will tomahawk the rest. If t will mow a half acre well then why won't it mow the rest?
There is a limit to how many hours you can get out of a machine. If you run a mower every day you will usually get more hours out of the machine than you will by putting 20 hours a season on it and storing it for half a year. You will probably only get 3 to 4 years out of it instead of the 10 to 15 years you will get out of it for personal use, but it will handle the job. When I was young I worked for a man who used residential murray 42" lawn tractors for a small lawn care business. I had to mow the town's ball park (3 baseball fields), while he and my brother mowed the cemetery. It had to be around 8 and 10 acres between the two places. We started at 7 am and usually didn't finish until around 2 pm. We mowed the park and the cemetery with those mowers for 2 seasons. Have you ever mowed anything like that with a residential mower? The raptor has a better engine, deck, and a much faster bts than those mowers did. You will never get me to believe that a raptor can't handle 20 hours a month.
