Ric
The op still has push mowers as back ups. I am guessing that the lawns are small enough that the op won't spend more that 20 to 30 minutes per lawn. Even at 30 minutes a lawn that's only 5 hours a week. Any mower should handle 20 hours of mowing a month. That's 100 hours in a mowing season. Are you saying that a raptor isn't designed to last 100 hours? I have personally put 250 hours on a $1600 lawn tractor with no major mechanical issues. That mower is still running and has close to 400 hours on it now. The op can more than pay for a raptor the first year. No need to invest in a commercial mower until he decides if that's what he wants to do with his career.
No the raptor is designed to be used for maybe 25 hrs a year, that's about what the normal homeowner would use time wise for a normal sized lawn. The problem comes in when his ten lawns turn into 15 or maybe 20 then what happens when his raptor goes boom and you lose a drive and he is stuck with all 20 lawns and a 21" push mower as back up and it's 90 to 100 degrees outside, what happens then. You end up with unhappy clients that will drop you in a heart beat and hire some other service to replace you.
Aside from that the mower is just to slow for commercial work with a 16.600 FPM BTS. Best way he can go is a used commercial and run it for a couple of years, save his money and if he decides to keep the business then buy the new Commercial to add to the one you all ready have. Use the new commercial and keep the old for back up.
