MAX ACREAGE TO CUT WITH A HUSTLER RAPTOR SD 54" MOWER
Hustler builds Quality Zero Turns...however their Quality Starts at the Fast Trak level of mower and up... any mower below the Fast Trak... NOT QUALITY..YOU HAVE BEEN WARNED.
http://www.lawnmowerforum.com/hustl...g-smooth-cut-any-idea-why-raptor-sd-54-a.html
Look at this thread, you can see what they cut. It's a light hearted thread because of all the Rapter debate ;)
With any residential machine if you work it hard it's lifetime will be shorter, if you can stop every couple hours and let drives cool down they will last longer, and also regular hydro oil changes.
Keep engine clean from debris under fan shroud and do regular oil and filter change, and also keep air filter as clean as possible engine will give long life.
How good machine cuts is in the eye of beholder.
If you plan to cut a lot go with a commercial machine you will be happier in long run.
Mike
I would usualy beg to differ. However in respect of your awesomeness I shall shut
my yap :biggrin:
Do note the subject addresses "SD" whilst the actual post talks about "HD".
Soooo.... where one dosen't know what one is riding then how can one know where
one can go...or how far how fast. That said, a JD rider could care less which yella fella
as long as he/she had one.
These questions (topic) would confuse Newton himself! :cool:
