needing help to identify Honda motor
billkater
I am needing help to identify a 24hp Honda motor on a Bush Hog TH420 UTV. Attached is the numbers on the motor
Thanks
Bill
Nothing to identify. You have all the info in your pics. GX670VAB2 / GCAM-1038195. That is all the info you need for parts.
Thank you for your help.
I didnt see the GX670 on any of the tags. What the best place to order a start?
Thanks
Bill
Hi Bill,
You are correct. My over-site. Early production listed the horsepower on the label. Later production listed the model (GX670). For parts, your best source is your local Honda Engine Dealer. You can use the dealer locator at engines.honda.com
These are not cheap aftermarket/rebuilt starters, so sometimes you can find used or 'factory' parts on Ebay or such for less.
Thank you,
Jim
