Repairs Blade falls off when trying to start
Someone has to do it
My mower is a 21" 3 in 1 rear wheel drive. It's a 175cc 7.75 briggs and stratton engine. I've already used it twice this season. I raised the mow height and when I tried to start it there was resistance. When pulling the start cord it comes all the way out and rewinds hard/fast. The first time it bucked and i ended up taking the handle in the chest. It felt like it was trying to start but just didn't catch. I started to tilt it to the side to see if something was binding it and heard the bolt/blade hit the concrete.
I put at new bolt, blade belt, and blade on. Torqued it to the recommended lbs/ft and tried to start again. Once again felt like it was trying to start. On the third pull I hear the bolt/blade hit the ground again. Is there something else I can check next?
shiftsuper175607
Is there dry grass packed under the deck that keeps the blade from spinning...thus the engine unwinds the bolt?
that sounds very strange...
Take the blade mount off and look inside where the crankshaft goes. See if the key is intact. I have seen this problem occur when the blade mount key is broken loose from the mount.
There was some dried dirt/grass at the top of the underside. I removed it before replacing the blade. I'll look tomorrow behind the gold colored piece the bolt goes in. I didn't look behind that.
SeniorCitizen
the engine must be running backwards :laughing:
So, remove the cover over the blade mount, loosen the belt around it, remove the mount. If broken, replace? Do I also need to check the flywheel? I'm watching a lot of you tube at the moment trying to figure out what I'm getting into.
The blade mount turns clockwise without binding. Occasionally there is a slight groan.
The key in most mounts is cast as part of the blade mount. if for some reason you strike an object it will break the mount. Then when you try to crank the engine and the engine stops, remember the blade acts like a flywheel also, so because of direction of travel will loosen the blade.
I've loosened the belt from around the blade adapter but the adapter doesn't want to slide loose. I don't want to damage the shaft? What can i use to remove it?
A lot of penetrating oil and a puller of some sort. A small amount of heat may not hurt anything either.
snapper388
I have the same mower with the same problem! mine sheared the flywheel key, when I pull the rope it would kick back ,snatch the rope out of my hand and drop the blade. mine was caused by hitting something with the blade.:frown:
