Gas leak Honda HTR3009
fiveacres
Fuel leaks very slowly from unidentified component (vented?) which is bolted to frame and connected by rubber line to carburetor. Does not leak with fuel valve in OFF position. Can't find schematic for fuel system to identify this part.
hi guy ! please i'm looking for the diameter exterior of the mufler (exhaust) on this lawntractor. could you check on your and tell me that ? kind regards
Please, please , please start a new thread.
Please do not tack a totally different problem onto the bottom of a thread that is 3 years old.
yes yes i know berts but i've tried ask my question where the owners of this mower are ! i understand, i go to go open a new thread.
sorry for my bad english i'm french
problem solved ;) outer diameter 24.4mm ;)
Sorry for slow response, see that you already found the info. Muffler intake looks like 7/8" diameter, exhaust 1 1/8". Did not measure with calipers.
