Vervepipes
- Mar 25, 2014
- Threads
- 13
- 357
Here is the toe biter with the Tecumseh Vector. The bolts are rounded off and I'm not too sure how to go about trying to remove them to save this powerhouse. Maybe cut them off and try to grasp the remnants with vise grips?...
The little Yard Machines that was cleaned up yesterday is sold. Here is today's project, an MTD rear bagger. I replaced the wheels, replaced the cracked handlebar, cleaned the rust off the muffler, found a good air box cover, re-seated the grass catcher onto it's wire frame, oil change, carb swap from a troublesome Craftsman that has been giving me issues, did a test mow and it's good to go. First pic as I got it.
The Craftsman that I pulled the carb from has had a few engines on it, it's the same deck that had a cracked oil sump. The replacement engine sputtered badly and I thought it was a carb issue, swapping it onto the engine above ruled that out, I now suspect a semi-sheared timing key, I'll try it another time when I have more time on my hands. I got 4 more mowers tonight that I need to sort through tomorrow.
