RedEyedRooster
I have a 2014 tiger cat STC52V-22FX with 83hrs. The cap came off the hydro oil the other day while mowing I found the cap lying next to the engine. Oils is below filler tube. Manual says to fill with 20w50 motor oil 3" 1/4 from top of filler tube. I don't know when cap came off and I cant see anything in the oil but I mow under some cedar, pine, and oak low limbs. Do I drain it and refill it, ya think. SAE 20w50 motor oil? what do you suggest (brand) I use Shell Rotella T Heavy Duty Conventional motor oil 10w30 in my motor with Wix filter but Shell Rotella doesn't make a SAE 20w50. You know I'm like everyone else I want this to last 1500-2000 hrs. Wore me out deciding on motor oil to use and I thought I'd have some time on the hydro oil but here I am. Another thing, do I go 500hrs before change hydro oil like the manual says or change more frequent(I guess it says annually). I mow up and down hills. 80 hrs is a full years mowing for me. Help me I'm worn out.
