Ric
How do you know a lawn tractor is easier to work on if you haven't owned a ztr mower? No hood in the way of the engine with a ztr mower. I have owned both, and I find that my ztr mower is very easy to service. Low end ztr mowers and lawn tractors both have similar drive trains, it's just easier to get to the engine on a ztr mower. Most ztr mowers also have a removable floor panel for easier access to the top of the deck. Which sounds easier to work on to you?
OK... you win. I was referring to less expensive parts and more availability of parts on Ebay for example.
No hood on my LX277, so there....hahaha
Shiftsuper I would guess that what you were referring too about less expensive parts and more availability you would be correct, the lawn Tractor would be cheaper too maintain. As far as working on either mower that would be a total toss up, I've had both. Yes you have a hood on the LT but it's a 30 second job to remove it. Same with a deck, remove a couple of pins and slide the thing out and replace what you want and put it back. I can tell there a lot lighter than a deck on a ztr especially a commercial. You can trust me when I tell you some of the ZTR's can be just as big a pita too work on and more expensive. It all depends on the mower you have. Personally I don't work on any, don't have to and don't have the time. They go to the shop.
