angellonewolf
thanks for any help
i recived a mountfield 16 sp mower tecumseh engine non working broken pullstart had been left for a year non running so i pulled it in took apart the pullstart and rewound it and put in tension and put back togethter cleaned the fuel out all way through and fresh fuel on the 2nd pull it started right up runs well and has a roller for striping the lawn but the belt is broken for the powered moving but will be used prob as a push mower but the engine does not switch off i think the problem is the plastic bit on the hope will supply pic for this
model number of engine is bvsr 153e41002099065b i think please see one of the pics
pic of engine number
as can been seen from this pic this is i think the problem is as when you pull off the slide conector the bit of metal that the slide conector conects to comes out with it for the plastic and if i put a meter over the metal hook to the slide contector i get a open circut
pic of top of throttle linkages
so for my help can any one post a pic of the linkages as i took it all off the other night and cant remember how it goes back together
and how does the the kill work on this from the handle i assume when you push back the lever the bar hits the plastic/metal hook to short the coil out
and can i use a cheap universial belt to get the powered mower but working again as the cost of the belt is stupid and hard to find
thanks for any help again
ps cant always reply right away as am at work
