New here...Need help with McLane 20" reel
Thomas56
I need help identifying what my problem is with the rear axle on my 20" McLane reel mower. I don't know if this is the correct subforum or not. The problem is that the rear axle shifts from side to side 1/4". It causes misalignment of the chains and sprockets and it has caused the reel chain on the outside of the mower to rub into the chain guard. I have a video of the problem on Youtube if someone wants to view it. I've got a parts manual and all of the parts seem to be on my mower. I just can't figure out where that 1/4" is coming from. It seems like a simple spacer or bushing may have fallen out but nothing like that shows up on the diagram.
If this is not the correct place for this, can someone steer me in the right direction. I've emailed McLane but I don't know what's up with them. They haven't gotten back to me.
Thanks in advance.
https://www.youtube.com/watch?v=bNYpjfQ0LsY
Tom in Decatur, Ga
Not familiar with this mower but my first thought is the bearings may have come loose.
Standard practice is to use self aligning bearings that are fixed to the shaft with a pair of grub screws.
These little buggers have a bad habit of coming loose which the allows the shaft to move sideways through the bearing.
They are easy to spot because the bearing will be held in place by a carrier with 3 or 4 bolts holding it to the side of the mower body and there will be an extension of the inner race on the shaft which is where the grub screws are.
Thank you. I will look for that.
