Every spring I spray my lawn with a hand sprayer using 24D. This year it was 60 deg. when sprayed.
The intended plants leaves curl up and some leaves die but few plants die.
I'm using 2oz of 24D per gallon with dish soap for a surfactant and a fine mist spray.
Am I not mixing a strong enough mixture to kill the clover and dandelion?
My lawn is 2 acres in size FWIW.
Did some searching here and Triplet works on clover, does it kill dandelion?
